Hi. I'm planning on designing a precision, low noise, variable power supply and with current up to 3A. To reduce noise I decided to us a transformer with a diode bridge to get a DC voltage instead of a switching power supply. It will need to generate 3 outputs: 14-16V to power my op-amps, a 5V supply to power the microcontroller and some other stuff like 5V fan, LCD or LED displays and an unregulated high current output that will be regulated elsewhere.
The image shows my design which includes a common mode choke, some filter caps and a MOV. So I would like some feedback on this design. Is this a good design or not? Also I've never designed anything that used a common mode choke so any comments on the AC Line filter are welcome.
Hopefully not all feedback will subscribe to Dave's shirt's philosophy and will be positive.
