Author Topic: Series of 3-legged "3011 Standards"???  (Read 1231 times)
Online ledtesterTopic starter
« on: June 04, 2025, 06:49:41 pm »
Does anyone have a clue as to what these are?
They are like 4 rows of them - each serially numbered.
Are they all the same device?
Seems like only #6 and #7 are missing.
Offline UnijunctionTransistor
  • Ohms Law: Resistance is futile.
Re: Series of 3-legged "3011 Standards"???
« Reply #1 on: June 04, 2025, 07:11:37 pm »
My best guess these were samples, requested by an OEM to make a statistical distribution analysis of the voltage,  which would determine which of all the listed vendors should be the preferred one and which the alternate.
But it is only a guess.
Offline Kurets
« Reply #2 on: June 06, 2025, 10:31:01 am »
2N3011 is a small signal NPN, usually in a TO-18 case but presumably it could also be requested in TO92 for a large customer. If you test one you should be able to determine what it is.
« Reply #3 on: June 07, 2025, 11:43:44 am »
I brought my transistor tester to the store and tested one of them. It tested as a NPN so you're probably correct.
I tried removing one of the labels but was unsuccessful. Probably could do it with a fine point tweezers.
My initial impression was that the number labels were added by the manufacturer as part of the device spec. but now I doubt that.
