Author Topic: Test Benches  (Read 2428 times)
Offline Pack34Topic starter
Test Benches
« on: January 12, 2014, 04:22:04 pm »
I apologize if this has been discussed before, but I made a couple quick test benches for some small breakout boards and modules. To create the test bench I cannibalized one of the boards, stuck headers on it and brought out all of the I/O to a microcontroller so I could run a quick exhaustive test.
My question is in regards to the connectors. Most of the connectors for these boards are standard 0.1" and are not soldered on after assembly. To test the boards I place the board-under-test on top of the cannibalized board and I have to hold it at an angle to get a good electrical connection. Does anyone know the name of a better test connector for this purpose? Perhaps one that tapers  or flares out like a banana plug connector?
What I have works, I just feel like there's a better way.
« Last Edit: January 12, 2014, 04:31:19 pm by Pack34 »
Offline Rufus
Re: Test Benches
« Reply #1 on: January 12, 2014, 04:34:01 pm »
Pogo pins.
Offline calexanian
    • Alex-Tronix
Re: Test Benches
« Reply #2 on: January 12, 2014, 06:29:59 pm »
Look in the POMONA catalog. I believe they have something for that.
Charles Alexanian
Alex-Tronix Control Systems
Offline con-f-use
  • Country: at
Re: Test Benches
« Reply #3 on: January 12, 2014, 07:57:52 pm »
Yes, spring-loaded, gold plated (less oxidation, lower contact resistance) telescope pins, aka Pogo-Pins. See how Sparkfun does it, and does it, and does it again.
« Last Edit: January 12, 2014, 08:12:10 pm by con-f-use »
Offline cellularmitosis
Re: Test Benches
« Reply #4 on: January 12, 2014, 11:42:40 pm »
I can't remember where I saw this tip, but I use pogo pins as an ICSP connector to program micro controllers.  Super convenient!
LTZs: KX FX MX CX PX Frank A9 QX
Offline zapta
Re: Re: Test Benches
« Reply #5 on: January 21, 2014, 10:30:53 pm »
Pogo pins.
Search eBay, there are plenty,  different shapes and good prices.
