Author Topic: Is CR-2477/VCN acceptable replacement for BR-2477/VAN ?  (Read 6107 times)
Offline plantgrowerTopic starter
« on: June 20, 2013, 11:41:58 pm »
I have an agilent 34970a which currently has a PANASONIC - BR-2477/VAN battery soldered in it that needs replacing is a  CR-2477/VCN  a suitable replacement as the BR variant is not available.
Offline Stonent
Re: Is CR-2477/VCN acceptable replacement for BR-2477/VAN ?
« Reply #1 on: June 21, 2013, 01:09:19 am »
I'd say yes, but....  BR are designed for more temperature tolerance than CR batteries.  If the battery is helping store calibration data, I'd make sure to some how wire up some 3V power in parallel to the battery so that you don't lose data when it is removed.
Technical Data - Table 1 - (CF)n/LI: Poly-Carbon Monofluoride (BR)
Technical Data - Table 2 - Mn02/LI:Manganese Dioxide (CR)
http://www.panasonic.com/industrial/batteries-oem/oem/primary-coin-cylindrical/br-cr.aspx
Coin type lithium batteries are high energy, high reliability batteries for a variety of applications. The 3 volts in these high energy density batteries is about twice that of conventional dry batteries.
Panasonic coin type lithium batteries are available in two types: poly-carbonmonofluoride lithium batteries (BR series) for uses that require extended reliability and safety over a broad temperature range and manganese dioxide lithium batteries (CR series) for uses that require and strong load pulse characteristics.
The CR Lithium primary coin cells contain Perchlorate over the limit specified by the state legislature of California and are therefore subject to requirements in the California Code of Regulations, title 22, division 4.5: Chapter 33 – Best Management Practices for Perchlorate Materials.
•Very safe (poly-carbonmonofluoride lithium)  <------------
•Extremely strong load pulse characteristics (manganese dioxide lithium)
•Operating temperature range:
•BR Coin Cells: -30ºC ~ +80ºC <------------
•CR Coin Cells: -30ºC ~ +60ºC
To be safe, probably should stick with the BR battery, you don't want it popping and ruining your nice gear.
« Last Edit: June 21, 2013, 01:15:22 am by Stonent »
Offline Stonent
« Reply #2 on: June 21, 2013, 01:14:02 am »
Ok scratch the part about CAL data
http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=1000001022:epsg:faq&nid=-11143.0.00&id=1000001022:epsg:faq
Is there a battery in the Agilent 34970A?
Yes. A 3.0-volt lithium battery, A1BT101, is used to power the real-time clock, stored state, and reading storage memory with line power removed. The battery has a nominal lifetime of 4 years and can be replaced by the user. The battery is soldered into the 34970A. This battery does not affect the calibration memory.
A low battery will typically give errors when ac line power is removed and then re-applied. Any of the following errors may indicate a low battery:
•201, "Memory lost: stored state"
•202, "Memory lost: power-on state"
•203, "Memory lost: stored readings"
•204, "Memory lost: time and date"
Replacement battery Agilent part number 1420-0860. Refer to the 34970A Service Guide for verification and replacement procedures.p.
« Reply #3 on: June 21, 2013, 03:56:01 am »
Does anybody know a stockist of a  BR-2477/VAN in the UK please ? Digikey list the Panasonic part but no stock  :--
Offline Stonent
« Reply #4 on: June 21, 2013, 04:35:33 am »
Looks like you just have to wait 2 weeks. I entered 1qty and got this:
Product Lead Time Estimates
Digi-Key Part Number P030-ND
Manufacturer Part Number BR-2477A/VAN
Description BATT LITH HITEMP 1000MAH PC PINS
Quantity
Ship Date Estimate
(mm/dd/yyyy)
1 7/5/2013
Offline Stonent
« Reply #5 on: June 21, 2013, 04:40:24 am »
Allied has them for export:
http://www.alliedelec.com/search/productdetail.aspx?SKU=70196835
Newark also
http://www.newark.com/jsp/search/productdetail.jsp?SKU=40T0046&CMP=AFC-OPF
Just to be sure, does your battery stand up or sit flat?
Offline nukie
« Reply #6 on: June 21, 2013, 05:34:50 am »
Microbattery.com
« Reply #7 on: June 21, 2013, 07:10:35 am »
Stands up on its edge.
I just noticed that too thanks. Looks like I'll just have to wait.
Offline matemathieu
« Reply #8 on: April 28, 2017, 02:19:40 pm »
For the record, I have changed the battery in the same Agilent 34970A chassis.
It was a SANYO cR14250SE already, so I have just replaced it.
