Hi everybody,
I am looking for large pogo pins, or spring-loaded connectors, with a large amount of stroke/travel (about 5mm is needed), e.g. similar to this one:
This is 5 mm grid paper, so the total length is about 15 mm, the stroke is almost exactly 5 mm. I feel quite lost here because I have spent hours clicking myself through the websites of the large distributors (Digikey, Mouser, etc.) and also sifting though the catalogue of Mill-Max, but I haven't found anything that comes close. Most connectors there are much thinner and only have up to 3 mm in stroke. This is particularly frustrating as I have seen similar sized Pogo-pins in the wild, for example they are used on this LTE-Module that can be put onto a Raspberry Pi Zero:
Does anybody here have a clue where I can look for such large pogo-pins, or did any of you already work with similar connectors in the past?
Any hint is greatly appreciated
Regards, Joel
