Author Topic: Latch-Up?  (Read 570 times)
Offline JesterTopic starter
Latch-Up?
« on: June 06, 2019, 10:25:17 pm »
Simple little 555 circuit below is acting up. Most of the time the 14s timer operates as expected, once in a while it stops early. I thought I could rely on the ESD diode at pin 2, but looks like that little spike is enough to cause problems.
Agree/Disagree?
Offline dmills
Re: Latch-Up?
« Reply #1 on: June 07, 2019, 01:29:12 am »
Something odd with the U8-2 trace as I would expect the rising edge of 10m to cause it to shoot up from 5V to something higher, and I would expect the falling edge to cause it to go low before slowly ramping back to 5V.
Not what we are seeing.
Regards, Dan.
The following users thanked this post: Jester
