Author Topic: Working on Adj Current/Voltage SMPS Lab PSU. Questions...  (Read 3817 times)
Offline FenderBenderTopic starter
    • The Solid State Workshop
« on: September 17, 2011, 02:49:29 pm »
Hi everyone,
I'm kind of a newbie so if I sound like a moron, that's probably why.
I'd like to design my own switchmode bench supply that can be configured to have an adjustable current limit and adjustable output voltage.
I like National's Simple Switcher chips, as I've used an LM2576-5.0V once before and it worked very well.
However, I need a simple way to do this and I don't want to use an L200c for that would mean huge transformer, huge heatsinks, and a big pricetag. At which point a commercial PSU is probably the best option. I figure that I can build my own for quite cheap if I use a switching design and have something that I can trust.
So I was going to try to use a LM2576-Adj which National has a nice 1-30V adjustable schematic for in the datasheet. But I'm too stupid to figure out how to do adjustable current limit. I know you'd probably need some op-amps or something, but really don't have much of an idea of how to do it correctly.
Then I saw the LM2673 which is called "3A Step-Down Voltage Regulator with Adjustable Current Limit", but it SEEMS that in the datasheet, that you can't have a very wide output voltage range due to something with inductors and capacitors and resonance they have with eachother. However, I don't know that for sure. LM2673 also switches at 260KHz which means I have more places to screw up my layout.
So I have a few questions. Does anyone have a decent solution to adding adjustable current limit to the LM2576? If not, how about getting a full range of voltage adjustment on the LM2673? If not, do you have any other ideas for this? Other chips/designs etc?
Thank you.
Offline Gall
  • Country: ru
Re: Working on Adj Current/Voltage SMPS Lab PSU. Questions...
« Reply #1 on: September 18, 2011, 09:38:38 am »
Generally, adjustable current limit is done independently of the chip. Voltage too.
You just measure both voltage and current using opamp-based circuits, compare them to references and provide a feedback to the regulator. The regulator may be SMPS or linear, doesn't matter.
The difficult we do today; the impossible takes a little longer.
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: September 18, 2011, 01:05:09 pm »
Take a look at power converters intended for charging batteries, since those need to control both voltage and current.
