Author Topic: Help Identify Q in Air Pump  (Read 391 times)
Offline NivagSwerdnaTopic starter
« on: September 23, 2023, 10:55:01 am »
I thought maybe there was a topic for component identification but cannot find it so creating a new one...
Device in my air pump seems to have split its side so presuming this is the cause of my problem.  Air Pump for a pond... this seems to be part of the speed control.
Not sure how to read those numbers... Thanks in advance
Re: Help Identify Q in Air Pump
« Reply #1 on: September 23, 2023, 11:02:47 am »
OK looks like a Triac
I cannot find any of them but I can source MAC97A8.  Does that sound like a reasonable swap?
I was reading mine as a 6... maybe it is an 8?
Online moffy
« Reply #2 on: September 23, 2023, 11:26:51 am »
As far as I read it, it is a MAC97A8, so it sounds like the correct part. Be careful if it is connected to the mains. It also looks like there might be signs of corrosion, check the resistors also.
The following users thanked this post: NivagSwerdna
Offline Andy Watson
« Reply #3 on: September 23, 2023, 11:39:12 am »
 MAC97 - sensitive gate triac. The other letters tell you where and when it was made, etc..
 https://www.sparkfun.com/datasheets/Components/General/MAC97-D.PDF
