Author Topic: PCB Holder for SMD assembly - microscope  (Read 17985 times)
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
Re: PCB Holder for SMD assembly - microscope
« Reply #25 on: July 15, 2018, 03:53:49 am »
Another option would be to put springs under the heads of the adjustment knobs.
That way you can have constant spring pressure without the risk of overtightening.
Offline rx8pilot
« Reply #26 on: July 15, 2018, 04:07:35 am »
I like that idea.
Offline rx8pilot
« Reply #27 on: July 15, 2018, 04:11:03 am »
This is what I use. I designed for my P&P machine but use it for general PCB holding tasks on the bench. It works with whatever odd shape PCB you have.
Offline Jester
« Reply #28 on: July 15, 2018, 03:26:48 pm »
I made a small tweak
My microscope with Barlow lens requires the board to be spaced up from the working surface by about 1" minimum, so I added removable feet (threaded stand-offs), this also allows for boards with tall components and also correct focus height for my setup.
Offline rx8pilot
« Reply #29 on: July 15, 2018, 05:06:03 pm »
+1 for the barlow lens - crucial accessory for electronics.
