Hi Guys,
i'm planning to test the TDA7294 D-mos power amp as an opamp - to use it as a output stage for my lab supply i'm designing (probably it will be useless , but we'll see
my question is the bootstrap pin #6- when operated as audio power amplifier - the attached capacitor is being "dragged" up & down by the output and therefore it's acting like a charge pump - making enough voltage above the top rail to drive the high side...
but if i'll operate it @ DC only, then it means no charge pump anymore , and as a result the max positive output voltage will be few more volts below the "possible" output level... one solution could be to use a small DC converter and simply feed the bootstrap pin with a voltage few volts above the top rail, but would that be safe ?
did anyone here used those audio power amplifier ICs purely @ DC ? any experience sharing would be appreciated
