Maybe you find this useful:https://www.beetronics.co.uk/c-marine/high-brightness/ip65They also have a panel pc:https://www.beetronics.co.uk/15-inch-all-in-one-touchscreen-pcHowever, this is only IP65. Do you need more (IP68K etc)?
My first thought would be some outdoor rated HDMI touchscreen - easy to find and probably the lest expensive option. Though I don't know how easy it is to use HDMI with ESP-32. If you can change to a Pi solution that would do it.
Budget? Its going to be hard to find unless you want to spend a reasonable amount, afaik.You can google IP67 touch LCD embedded (or IP66, whatever), and you'll find some results.You could take the existing crowpanel display, and seal it inside a waterproof enclosure. So the front glass will still be accessible.I've never seen touch panels work that well when it is raining directly on them though. So thats something for you to test.
..Need it to be installed on the boat, so wet hands, rain, etc. I would like to control it with ESP32 (nothing special about the graphics, only some buttons to press .
Cross posted here: https://www.eevblog.com/forum/reviews/lcd-outdoor-touch-display-(esp32)-5-10-inch-where-to-find-456107/Maybe you can delete that thread.Quote from: thm_w on March 18, 2025, 10:07:58 pmBudget? Its going to be hard to find unless you want to spend a reasonable amount, afaik.You can google IP67 touch LCD embedded (or IP66, whatever), and you'll find some results.You could take the existing crowpanel display, and seal it inside a waterproof enclosure. So the front glass will still be accessible.I've never seen touch panels work that well when it is raining directly on them though. So thats something for you to test.
IP65 is ok, but those are HDMI, esp32 will not work with that, should be parallel connection or SPI but i guess it will be difficult to find such displays. This would require to switch to Pi that will need my project design rework complitly .. esp32 was choice for esp-now protocol and easy communication and of course very very cheap price.
