Some time back, I funded a Kickstarter campaign whose product was a small Tesla Coil kit. The kit is the "Tiny Tesla", and you can find out more info about it on their web site:
http://onetesla.com/I have some questions about problems I've had with the kit, and also about Tesla coils in general. While the OneTesla site does have a forum, they tightly control posts, and it sometimes takes them as long as a week for the moderator to approve a post. That just makes it impossible to carry on a conversation. So for that reason, I thought I might have better luck with my questions here.
I received the kit a few weeks ago, and assembled it over the weekend. The active electronics portion of the kit seem to work pretty well, but I had a really bad experience with the arcing within the secondary coil and between the secondary coil and the primary. The instructions, and what little helpful posts there are on the OneTesla forum, repeatedly stress that you need to coat the secondary with at least 3 or 4 coats of some sort of varnish - they recommend polyurethane. This seems to be the only solution they propose to peoples' problems with arcing within the secondary coil. Well, I put 6 very thick coats of MG Chemicals Super Corona Dope on the coil before testing it out. This is a product specifically designed for high voltages, so I figured it would work better than polyurethane . It didn't prevent arcing. Reading posts on their forum, it seems many coats of polyurethane didn't help either.
So I am wondering if the design of the coil is just bad - maybe the dimensions are such that the voltage gradient across the coil is just too high? Or maybe the top load needs to be higher above the secondary coil (i.e. farther away from the primary)?
Anyway, if you have any experience with these things, I would love to get some advice. Despite the problems, I did have some success with the coil before it eventually burst into flames, and I'd really like to try again - doesn't have to be a kit. But I'd like to learn more about how to be successful with the design before spending more effort on it.
