Pg. 93 footnote: "30 The connection between Early voltage and ? is ?=VT/(VA+VCE)? VT/VA; see Chapter 2x."
The given answer above explains the -x chapters as part of an upcoming, already written but not yet released book. I expect you'll find identical references in the printed version.
Thanks. Indeed my printed copy has the same erroneous cross-references. They are not, however, references to a chapter twentysomething, but rather to chapter two-point-something. For example, a few pages later a footnote says to refer to chapter 2x for more discussion of current sources and current mirrors. Current mirrors are discussed on pp 101-105 or so, just a few pages later, still within chapter 2.
I’ll have to check whether the errata on the AoE website has been updated to reflect these.
In any case, I hadn’t noticed these errors until you mentioned them. Yet another disappointing lack of quality control in this book.
