Presently i'm investigating an issue with broken soldering joints on a PCB that has been thermo cycle tested. I think I have found a possible root cause to the issue, but I lack someone to ask for a second opinion and look with "fresh eyes and mind".
Automotive application
-40'C to +85'C ambient and locally up to 110'C on the PCB surface
Lead free components, mostly with matte Tin finish on the solder terminals
Leaded solder paste, SnPb 60/40 or SnPbAg 60/37/3 (Demand from some customers)
SMD packages 0402, 0603, 1206, SMB, SMC, SOT23, QFP44, pin header 2x2
Dual side assembly, ie two runs through the assembly and soldering line
6 layer PCB, FR4, gold plating on all solder pads, RoHS compatible
All copper plane solder pads have thermal relief
Peak temperature during reflow is just reaching 230'C for a single panel
My idea, so far, is that the peak temperature during reflow is a bit too low. As pure Tin melts at 232'C, the surface material on the components is not melted by the solder paste, thus they will not form a fully mixed soldering joint. The two different metal alloys in the joints will have different thermal properties and cause mechanical stresses and cracks during thermal cycling.
We have also seen signs of poor wetting on SMC diode packages where in one case only half of the soldering terminal had a nice solder slope. Oxidation due to unproper storage conditions has been discussed but the actual shelf time at the assembly house is less than a month and in a sealed plastic bag. The SMC package is on of the larger components on the PCB, so it could be related to temperature.
Both Murata and Diodes points out in datasheets and appnotes that Matte Tin finished components must be soldered with a peak temperature above the melting point of Tin (232'C). Our PCB assembler claims that they can use approx 225'C and compensate the lower temperature with longer time above the liquidous temperature of the solder paste (183'C). Personally I doubt that and my gut feeling is that they are clueless and are in a state of total denial.
All kinds of input, both personal reflections and/or links to relevant documents are highly appreciated. Is soldering temperature the most likely explanation or is there something else I have missed totally and need to check up?
