Author Topic: Leaded solder recommendation (China import?)  (Read 10425 times)
Online ebastlerTopic starter
« on: November 30, 2021, 10:57:07 am »
While I have moved to lead-free solder for some of my hobby work, I still need leaded for repairing old stuff, and I do prefer it for through-hole joints. I didn't see the EU ban on leaded solder for consumer customers coming, so my stock is running low.
Buying directly from AliExpress seems to be one of the few remaining options. Can anyone recommend a brand of leaded solder with good flux which is available there? (Good activation, easy cleaning, not-too-nasty smell while soldering? I had some Stannol solder with halogen-free flux which gave off a terrible vapor; would prefer not to repeat that experience...)
Thanks for your recommendations!
Online magic
Re: Leaded solder recommendation (China import?)
« Reply #1 on: November 30, 2021, 03:35:17 pm »
I once bought some no-name solder from an auction site and the flux had an absolutely awful smell. Kinda like reflowing solder joints in bottom of the barrel electronics from China, go figure. So I would be careful with AliExpress specials too.
Try brick and mortar stores or even hobby oriented internet stores selling brand name solder. A least here, many of them still haven't got the memo (or pretend so).
Offline Phaseseeker
« Reply #2 on: November 30, 2021, 03:56:07 pm »
I checked Mouser and they seem to still carry leaded solder (both 60/40 and 63/37) with no apparent restrictions. Also, my local electronics store (I'm in Italy) still has it and the last time I bought some (a couple years ago max) they didn't even say a thing about it being banned; no idea which brand it is (the spool simply says "super solder wire") but I've never had problems with it (it doesn't have that nice rosin smell though)
Offline tunk
  • Country: no
« Reply #3 on: November 30, 2021, 03:59:45 pm »
Not used it myself, but I think it has been mentioned
in other threads that the Mechanic brand is ok.
Offline paul_g_787
« Reply #4 on: November 30, 2021, 04:09:31 pm »
I buy my solder from CPC in the UK. I only use leaded solder. I never bother with the lead free.
https://cpc.farnell.com/multicore-loctite/x-39-60en-2c-0-7mm-s-500g/solder-wire-x39-22swg-500g/dp/SD02681
« Reply #5 on: November 30, 2021, 06:48:44 pm »
Thank you all!
Local shops -- brick & mortar as well as mail order -- don't seem to be an option any longer. They all seem to have taken leaded sholder off their shelves in the course of the past year or two.
(Long after RoHS became effective, and frankly I am unsure what regulatory requirement was driving this. RoHS only applies to electrical and electronic equipment. I.e. one can't use leaded solder in the manufacture of such equipment, but one can use it to make non-electrical stuff, repair old equipment, and of course for any hobby work which does not result in products that will be "put on the market". And I can't find any clause in the RoHS directioves that would stop a company from selling leaded solder in Europe.)
Anyway -- you seem to be right that non-EU vendors based e.g. in the US and the UK will still happily ship  to Europe. I am pretty sure that Mouser told me "sorry, can't ship this to Europe" when I tried to order leaded solder early this year -- but today I could get all the way to the "pay now" button without any objection. Same for CPC/Farnell. I have not pulled the trigger yet since I want to combine this with other parts to be ordered, but it seems to work now.
So thanks! I am much more comfortable buying solder from a known brand than some no-name import.
Online magic
« Reply #6 on: November 30, 2021, 07:12:37 pm »
It's not RoHS but some other idiocy about toxic substances and whatnot. There have been a few threads about it here.
You can't buy lead alloys of any sort at all. But you still can buy lead ammunition and fishing weights so that's how I source lead when I need it ::)
Offline jpanhalt
« Reply #7 on: November 30, 2021, 07:21:19 pm »
Amazon has Kester 44 solder in the US: https://www.amazon.com/s?k=kester+44&crid=25ROIXGCIKUXM&sprefix=kester+%2Caps%2C198&ref=nb_sb_ss_ts-doa-p_9_7
I only mention it, because it may have cheaper shipping.
Offline NorthernWing
« Reply #8 on: November 30, 2021, 07:31:35 pm »
I'd obviously keep looking for a source for good Kester #44/etc, but if you absolutely have to buy from Asia then I've used Mechanic branded 63/37 solder from LCSC and it's acceptable - the flux core was basically nonexistent in the spool I had and so I used a lot more RMA flux out of a can on those projects, but the solder itself turned out to be decent.
Offline tooki
« Reply #9 on: December 01, 2021, 09:18:21 am »
Thank you all!
You are correct: you couldn’t find a relevant RoHS clause because there is no RoHS clause that applies to components. The reason shops can’t sell you leaded solder is because of the separate REACH regulation: https://blog.assentcompliance.com/index.php/difference-reach-rohs-compliance/
But yeah, you can readily order it from Mouser, Digi-Key, Farnell, etc. And many shops in the EU will sell you leaded solder if you say it’s for commercial use.
With that said, I don’t think modern lead-free solder is hard to work with at all. My favorite one so far has been the Felder ISO-Core "Ultra-Clear", Sn100Ni, which I got from Reichelt. I like it better than the Stannol, and it’s even a bit cheaper. Is it quite as nice as Kester 44 63/37? No. But it’s close. I’d choose the Felder over Stannol 60/40.
The only time you see difficulties with lead-free that you wouldn’t with leaded is when you are working at the absolute thermal limits of your soldering equipment, when your board is sucking away so much heat that you need every little bit. But frankly, the real solution is to choose a larger tip and maybe get a more powerful station.
Offline tooki
« Reply #10 on: December 01, 2021, 09:19:39 am »
Mouser, Digi-Key and Farnell all offer free shipping to Western Europe on orders above around €50, so it’s easy to just add a roll of solder to an order you’re placing anyway.
Offline maxwelllls
  • Country: cn
« Reply #11 on: December 01, 2021, 09:52:47 am »
T12 solder is highly recommended, it can rise to 350℃ in about 10 seconds with a fast heating speed. You can find many brands, all of which are designed based on HAKKO's solder tip. You can even DIY a set through open source solutions, and the price is very cheap, less than 30 DOLLARS. A good alternative is' MECHANIC T12 Pro 'from AliExpress.
« Last Edit: December 01, 2021, 09:56:20 am by maxwelllls »
Offline tooki
« Reply #12 on: December 01, 2021, 12:31:02 pm »
This discussion is about solder, not soldering stations!
Solder is the metal that you melt when soldering. It’s the material, not the equipment.
« Reply #13 on: December 01, 2021, 07:10:22 pm »
Thank you again to all recent contributors. I will add a roll of leaded solder to my next Mouser order (who knows when importing will be restricted too...), but will also try the Felder ISO-Core "Ultra-Clear" lead-free which tooki recommended. Maybe there is room for improvement over the Broquetas ECO-4 (Sn96.5Ag3Cu0.5, bought from TME) which I currently use for lead-free soldering.
By the way, I had looked at the REACH shortly after posting my earlier message, when it occurred to me that this might be the relevant regulation which prohibits sales of leaded solder. But it seemed to me that REACH only restricts lead for use in jewelry, shot, or things children are expected to put into their mouths.
Of course, the REACH registration requirements do apply for all lead products -- maybe the European sellers just couldn't be bothered with those? Not too likely that all major distributors would have reached tha conclusion more or less in sync though; there likely is some regulation which I am overlooking which actually prohibits sales to consumers.
Online magic
« Reply #14 on: December 01, 2021, 07:49:05 pm »
There was a thread or two about it since the ban appeared (March 2018 or 2019 IIRC), complete with links to some EUrocrat website with detailed information. Find it and you will know.
edit
https://ila-reach.org/2018/01/new-restrictions-and-labelling-requirements-affect-lead-from-march-1-2018/
That has some detail, hopefully you will be able to trace the relevant regulations from there if you are masochist enough to try.
I CBA to investigate any further, death to EU, death to America, fuck all this socialist bullshit, gimme nuclear war >:D
« Last Edit: December 01, 2021, 07:58:58 pm by magic »
« Reply #15 on: December 01, 2021, 10:31:54 pm »
Thanks, magic. So they did indeed extend the scope of the earlier REACH directive which I had found, and have explicitly restricted the supply of lead-based products to consumers. It's not about protecting the environment in this case, but protecting us stupid sods from poisoning ourselves.  ::)
(Unless we elect to poison ourselves by licking lead-based ammunition, lead sheets for architecture, or lead-based batteries, which are OK.  :palm:)
Online xavier60
« Reply #16 on: December 01, 2021, 11:40:31 pm »
There are low working temperature lead free solders for sensitive components.
This is what I have been using for power LEDs.
  https://www.caplinq.com/buy-bi58sn42-eutectic-leadfree-low-temperature-melting-solder-spheres-solder-balls-online-bi58sn42.html
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline maxwelllls
  • Country: cn
« Reply #17 on: December 02, 2021, 01:36:18 pm »
sorry for my poor english,but MECHANIC still is a good choice,It's my favorite brand,You can choose from lead-free wires with a melting point of 210 ℃ or even ultra-low ones with 138 ℃
« Last Edit: December 02, 2021, 01:47:30 pm by maxwelllls »
Offline paul_g_787
« Reply #18 on: December 02, 2021, 05:35:30 pm »
I always buy my solder from a reputable manufacturer such as CPC / Farnell / Mouser. Whoever I need to do an order with for free shipping usually :)
Multicore is the brand CPC stock.
I have not really found a difference using different 'brands' as such.
What you want to search for is 60/40 solder (which means 60% tin, 40% lead) with rosin flux core.
I am not a fan of the 'no clean' flux for general soldering applications. It is easy enough to use some IPA alcohol and cotton buds to dissolve the remaining rosin residue afterwards.
Offline zzattack
« Reply #19 on: December 02, 2021, 06:18:53 pm »
Agreed with Paul, the loctite/multicore 60/40 is affordable, well available, flux is effective but leaves minimal easily cleaned residue, does not smell and exists in a good variety of diameters.
Offline tooki
« Reply #20 on: December 02, 2021, 10:56:39 pm »
I don’t understand why people recommend 60/40 other than habit: 63/37 is no more expensive these days, and in hand soldering, it is just that little bit better that makes it nicer to work with. 63/37 is true eutectic, 60/40 is near-eutectic, but not quite, meaning it has a brief moment when cooling down during which it’s in a slushy state, subject to disturbance. True eutectic goes straight from liquid to solid with no in between.
The following users thanked this post: ebastler, Steffalompen
Online xavier60
« Reply #21 on: December 02, 2021, 11:08:29 pm »
I just noticed, my 138℃ solder wire here is MECHANIC XW5. Works fine. Care needs to be taken as to where 138℃ solder should be used.
Offline sleemanj
  • Professional tightwad.
« Reply #22 on: December 02, 2021, 11:13:06 pm »
For china sourced solder, I prefer "Best" brand myself, or at least I have a few spools of it with good results.  According to the label it has a higher flux content than most at 2.25% which probably helps.
Of course, from china so YMMV from one day to the next.
Offline lfldp
« Reply #23 on: December 03, 2021, 09:45:23 am »
hi! if you wants to solder with lead-free solder wire and enjoy similiar effect to leadded solder you may try patented lead-free core wires Sncu+NiGe , ive use STANNOL solder wires lead-free type but with added nikiel+germanium with it you get similiar effect to leadded solder (just dont exceed tip temperature a lot)
this is patented core wire type and there also few other companies who manufacture this kind of solder wire
i attached photos with solder wires which i use and i can highly recommend it , when i soldering with usuall lead-free solder wire sometimes i must add flux to getting desired effect but by soldering with Sncu+NiGe i have no problem at all its 95% nearly like leadded solder !
Offline lfldp
« Reply #24 on: December 03, 2021, 09:49:25 am »
and btw. the sciencist still working on to find proper materials for replace leadded alloys to getting desired or similiar soldering effect and i am sure in near future they finally find 100% equal solution to eliminate this poison from soldering products
Offline lfldp
« Reply #25 on: December 03, 2021, 10:15:39 am »
SN100Cu0,7NiGe is lead free solder wire with nikiel and german but there is also another one called Sn100Ni+ that one have added only nikiel , does someone compared these two solder wires and can write there some opinions ? because ive heard Sn100Ni+ like this one https://www.conrad.pl/p/cyna-lutownicza-bezolowiowa-felder-loettechnik-iso-core-ultra-clear-sn100ni-5551941010-szpula-sn9925cu07ni005-0100-2226468 is good too
the one from link is completly colophony free formulated from syntetic resins same as solder flux most of syntetic resin based are very pleasant when inhalle
« Last Edit: December 03, 2021, 10:17:30 am by lfldp »
Offline lfldp
« Reply #26 on: December 03, 2021, 10:28:36 am »
sorry for my bad english ill try to explain deep
what i mean exactly is by soldering with lead-free type Sn99Ag0,3Cu0,7 usually i getting moustache from solder and to remove this effect i must add more externall flux to remove this but by soldering with SnCu0,7NiGe i dont getting this effect , if i slow down tip temperature a little i getting similiar effect to leadded soldering - didnt getting these moustaches and this is what i need exactly
is a whiskers https://www.google.com/search?q=lead+free+whiskers&tbm=isch&ved=2ahUKEwj9qfT8tcf0AhVw_SoKHRwDBHwQ2-cCegQIABAA&oq=lead+free+whiskers&gs_lcp=CgNpbWcQDDoHCCMQ7wMQJzoECAAQEzoICAAQCBAeEBM6BggAEAgQHlCzB1jiEGDzHWgAcAB4AIAB1wGIAfgFkgEFOC4wLjGYAQCgAQGqAQtnd3Mtd2l6LWltZ8ABAQ&sclient=img&ei=ZPGpYf3nI_D6qwGchpDgBw&bih=912&biw=1920#imgrc=hlbUoDbXdowTrM
and these whiskers are eliminated by nikiel+german added to solder wire so this is big difference beetwen common lead-free solder deffect
« Last Edit: December 03, 2021, 10:31:35 am by lfldp »
Offline tooki
« Reply #27 on: December 03, 2021, 09:45:43 pm »
Tin whiskers have not proven to be the problem they were predicted to be. They apparently almost entirely come from pure (100%) tin plating, not from solder.
What do you mean by a mustaches? We don’t use that term regarding soldering.
Offline lfldp
« Reply #28 on: December 04, 2021, 08:05:38 am »
tin whiskers means when you soldering with SAC305 or another lead-free with solder iron usually you get effect like on this photo:
https://oscarliang.com/ctt/uploads/2017/07/solder-lead-lead-free-60-40-differences-3.jpg
after that you need add flux and heat again to remove this bad effect , but with SnCu0,7NiGe soldering you wont getting same problems , you dont need  to add any other flux to fix lead free soldering effect so this is quite difference and SnCu0,7NiGe it not works exactly like leadded alloy but much more better than usuall lead-free alloys
another question is how this soldering wire works Sn100Ni+ by comparing to SnCu0,7NiGe
« Last Edit: December 04, 2021, 08:07:34 am by lfldp »
Offline TomS_
« Reply #29 on: December 04, 2021, 08:31:10 am »
Hmmm no. This is not tin whiskers. Just dodgy soldering. :-)
Tin whiskers are extremely fine metallic growths which, in the wrong circumstances, could cause a short from the pin which they grow to an adjacent pin. Or if they become detached could be blown around by air movement and short some other pins elsewhere.
At a previous company that I worked at we were even requested to inspect the underside of (raised) floor tiles in some certain telecommunications facilities that we were based in to look for tell tale signs that the floor tiles may pose a tin whisker hazard to our equipment.
Online magic
« Reply #30 on: December 04, 2021, 08:42:17 am »
Specifically, it looks like inadequate technique for noneutectic alloy ;)
And more specifically, manipulating such alloy in its intermediate phase.
BTW, the saving grace of noneutectic lead-free solder is that the intermediate phase behaves like a paste, which makes it very easy to remove :D
Offline lfldp
« Reply #31 on: December 04, 2021, 06:32:18 pm »
ok i understand
Offline tooki
« Reply #32 on: December 04, 2021, 06:51:50 pm »
Yeah, something is getting lost in translation here, because that’s got nothing to do with tin whiskers. (Google the phrase “tin whiskers” to see what it actually means in English.)
And I agree that the photo doesn’t show anything other than bad technique. That has little to do with the alloy.
Offline strawberry
  • Country: lv
« Last Edit: December 06, 2021, 02:11:34 am by strawberry »
Offline Steffalompen
  • Country: no
« Reply #34 on: December 06, 2021, 02:30:04 am »
It continues to amaze me, the too common faith that some future technology will make a perfect substitute, even of chemical elements (and simple alloys thereof), without some other complication arising.
