These are something I work on regularly. The scanner amp for a high speed galvanometer scanner. The scanner has a led and two or four photodiodes in its base with a moving flag. This forms a photosensor that sources differential currents as A and B feedback inputs. A closed loop current source linearizes the feedback sensor. Once you know that, you have low frequency damping, high frequency damping, servo as proportional. The other feedback means is EMF from across the Galvo coil. This is for a Cambridge Technology 6850 amp. The new ones are often DSP based. Capacitor and Resistor values change by model of galvanometer and its shaft inertia/resonances/ sensor gain. The next step up adds a notch filter assembly, not shown. An LM3886 is used as a power Op-amp.
Enjoy....
Steve
