Over the last few months I've been putting together a project that involves a array of color LEDs in specific wavelengths of red, green and blue. Because the wavelengths required for my use case are so specific (440nm, 535nm, 660nm), and the blue and red particularly are outside the bounds of what you would readilyfind in a multi-color emitter I've had to use separate emitters per-color, which is causing some problems when it comes to mixing the three colors. I've attached a photo of my emitter board, which as you can see uses alternating rows of each color. The problems that arise from this are what you would image: the individual rows of color are discernible through most simple diffusers, and the problem is particularly bad on the edges where one color dominates. I've been thinking of few possible solutions to this:
1) Decrease the spacing between the emitters and alternate them in a repeating pattern (RGBRGBRGB) the way pixels in a monitor or the photo sites in a camera with a bayer array are arranged. This would potentially help with mixing, but would reduce the size of the array and make routing much more complex.
2) Explore more complex diffusers. Currently I'm actually using the multiple layers of material I pulled out of a broken tablet LCD, which appears to be a combination of light channeling sheets, multiple fresnel lenses and a diffuser. This is a big improvement over the simple plastic diffuser, but I'm not sure how I would source this material, and there are still issues on the edges of the panel where one color dominates.
3) Move the emitters to the edge of light, or add a mixing chamber, which would probably work well but would drastically reduce the brightness.
4) Get custom RGB emitters made. I know there are vendors that do this, but I don't know how much it costs and what the minimum order quantity is. Seems like it would be a big resource commitment.
Any suggestions or advice would be helpful.
