Author Topic: LED project  (Read 387 times)
Offline richb007Topic starter
LED project
« on: November 02, 2024, 06:42:15 pm »
Hi Experts
Can anyone advise on whether this is possible and if so where to start getting it made.
Circuit board to operate a group of app controlled colour changing LED's
The complete product is made of several individual colour changing LEDS working as a group.
The circuit board operates a small RGB LED system with individual controls for each LED and is managed via a Bluetooth-enabled smartphone app.
Each LED illuminats a thin layer of  plastic alowing them to change colour as a group or individualy
It uses a rechargeble battery and is optimized for longevity on a single charge, ideally 4-5 hours.
The app will allow the LEDS to change or cycle colour on user request.
The product will include a wireless charging pod for each LED in the group
The board is ultra-compact, ideally under 5mm x 5mm, as thin as possible, and may include the following components:
1. RGB LED: Positioned for maximum light diffusion, allowing color changes and flashing sequences.
2. Bluetooth Controller: Enables wireless control over color changes and flashing sequences from a smartphone.
3. Microcontroller (MCU): Manages individual LED settings and coordinates group functionalities.
4. Rechargeable Battery: Thin, lightweight Li-Po or thin-film battery to power the LEDs.
5. Power Management IC: Regulates charging and manages battery efficiency, with charging contacts designed for a low-profile fit.
I know its a long read but any advise is welcome
Cheers
R
Offline Benta
Re: LED project
« Reply #1 on: November 02, 2024, 08:15:00 pm »
Offline Andy Chee
Re: LED project
« Reply #2 on: November 02, 2024, 08:50:52 pm »
It sounds like you want your RGB LEDs to behave like a WS2812 light strip, BUT you want the LEDs to be individually powered and communicate wireless?
Re: LED project
« Reply #3 on: November 02, 2024, 08:57:19 pm »
Yes thats right,
From the app i will be able to make all in the group a single or multicoloured.
my main concern is the size, and mainly the battery size.
i have seen the LEDs, and the chips for Btooth and they will fit, its battery im worried about
Offline Andy Chee
Re: LED project
« Reply #4 on: November 02, 2024, 09:27:03 pm »
Well let's do some energy consumption budget calculations:
According to the WS2812 datasheet, Red 12mA, Green 12mA, Blue, 12mA
Microcontroller, maybe 5mA
Bluetooth module, maybe 30mA
So you're looking at a battery size of around 350mAh
https://www.ebay.com.au/itm/335559843441?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=wm03nsyzrea&sssrc=2047675&ssuid=&widget_ver=artemis&media=COPY
Offline Kim Christensen
Re: LED project
« Reply #5 on: November 02, 2024, 11:45:40 pm »
Is this a typo?  ::)
