Author Topic: QSPI NOR Flash Part Compatibility Identification?  (Read 130 times)
Offline ricko_ukTopic starter
« on: November 03, 2024, 12:03:46 am »
I am not familiar with QSPI NOR FLASH. Is there some reliable way to:
- either check if any of the attached NOR FLASH are compatible with the N25Q128A13EF840E (datasheet also attached)
- or find one which is 100% compatible?
Ideally a drop in replacement, but it does NOT have to be footprint compatible! The size can also be the same or larger
Perhaps the "25" or "25Q" or "25Q128" in the part numbers guarantees that?
Or some online part comparison tools maybe from those manufacturers (I could not find any)?
I could obviously go through the datasheets but - apart from being time consuming - small (but very important) details might be missed when comparing them.
Thank you :)
« Last Edit: November 03, 2024, 01:09:11 am by ricko_uk »
