I'm thinking of making a circuit that flashes individual LEDs in sequence to spell a name; we can call it ABCDE for purposes of discussion.
At the moment I'm exploring options to drive it (I know a 4017 is the choice, but not sure if I can get more resolution/channels using an FPGA).
Anyway, I'm curious how far apart to space the LEDs so it's not blurry, and brightness. I'm thinking tiny surface mount so they are somewhat invisible when off, and then clearly spells ABCDE when on. Also, how big should I make each letter to avoid using many LEDs (I'd be soldering by hand) to fill each letter, but not so small that the letters are not clear.
I've seen through-hole LED projects, but, when off, the LEDs make it appear too obvious with little surprise to the naked eye when lit.
