Hi all
I've just finished designing a PCB for an LC meter based loosely on this circuit:
http://www.rfcandy.biz/communication/imp_lc.htmlSince it will probably take a month to get the boards manufactured I thought it would be wise to seek a little feedback from you guys before I sent it off!
I have built a prototype using leaded components and a breadboard to prove that a) the reference schematic is correct, and b) I can actually use the mega328P the way I had envisaged. I have also double checked the pattern and datasheet pinouts, and physically laid the components out on a printout of the PCB to check sizing.
Since I've never used SMT or made a PCB before it's hard to know whether I have made any bogus assumptions in the translation from through-hole to SMD, or about PCB design in general. Enter EEVblog experts!
The circuitry around U2 is the oscillator and operates at <580kHz. The two relays on the back are used to switch in a calibration cap and change the LC tank configuration for measuring either L or C. I have tried to keep the traces and layout in that area fairly tight to minimise parasitics, though I'm really just guessing at how well it will work
(for reference, it works fine on a messy breadboard so this probably isn't actually too critical).
