Author Topic: Lexmark toner chip Ti046b1  (Read 125311 times)
Offline karamouse
Re: Lexmark toner chip Ti046b1
« Reply #225 on: August 23, 2023, 11:24:06 pm »
good evening I have a simple question: is that after the reset
of the chip, the non-renewable page counter becomes 100%??
« Last Edit: September 04, 2023, 04:41:45 pm by karamouse »
Offline JacquesBBBTopic starter
« Reply #226 on: December 10, 2023, 06:53:06 pm »
Hello to All,
After a five-year break, I come back to this topic, still unsolved, but with great progress.
I  have seen that the market for  toner chips has evolved, and while they were around 25$ when I started this thread,  I could buy some for just 4€ here
https://www.aliexpress.com/item/1005006137482651.html?.
I tested it, and it works.
The chip is not at all as in the site picture, but more like the original Lexmark chip.
Lexmark :
with pinout :
Ljiayin chip :
see the attached photo, with the annotated pinout. Of course, the connector is the same
JP1 : GND
JP2 : SCL
JP3 : Vdd
JP4 : SDA
But what is this chip ?  Can anybody guess from the pinout  and find a datasheet ?
The marking is
17024D
2229
I asked Chat GPT, but although he  made some effort, he was not able to say more than stating that it was a I2C eeprom.
« Last Edit: December 12, 2023, 01:47:00 pm by JacquesBBB »
The following users thanked this post: voltsandjolts
Offline takha
  • Country: dz
« Reply #227 on: December 12, 2023, 01:33:25 pm »
i have lexmark ms410d imprimante but my toner imprimanta is empty, i would to programmer the puce TI046B1 of the toner .
 if you can i help me
 thanks
Online coromonadalix
« Reply #228 on: December 12, 2023, 03:39:41 pm »
@ takha
please refrain of doing  multiples requests the same day  or trying to pull answers     you may get  banned here
if people can or want to answer they will on their own terms  not yours
« Last Edit: December 13, 2023, 09:40:17 pm by coromonadalix »
Offline takha
  • Country: dz
« Reply #229 on: December 13, 2023, 03:33:52 pm »
@JacquesBBB
hello ,
I established these connections for reading the TI046b1 chip using a Pickit 2 programmer.
« Last Edit: December 13, 2023, 07:32:40 pm by takha »
Offline Diusha
  • Country: ua
« Reply #230 on: January 07, 2024, 03:39:22 pm »
Guys, you can write information in the chip by resetting all the counters, but you will not be able to reuse the chip in the printer, since the printer remembers the serial number of the chip (which is signed)and the number of printed copies, all you can do is exchange information from your chip or if you hacker you can modificate firmware. Original chip can be completely rewritten with new data, but it is microcontroller which listen only command for it programmed (toner, drum or developer if chip present in printer)
Offline takha
  • Country: dz
« Reply #231 on: January 09, 2024, 08:23:05 am »
hello Guys.
hello i can read the eeprom memory, but i can’t write can anyone help me?
I can’t attach to you my picture electrical system concerning the cabling with the program PICKIT 2.
Offline Diusha
  • Country: ua
« Reply #232 on: January 09, 2024, 02:18:16 pm »
If you able to read so you can also write, it is not problem in electric circuit. Commands beginning for read toner: 0xf0 , 0x01 , 0x01 , 0x00 , 0x00 for write toner: 0xf0 , 0x01 , 0x02 , 0x20 , 0x00 for read drum 0xf0 , 0x05 , 0x01 , 0x20 , 0x00 for write drum: 0xf0 , 0x05 , 0x02 , 0x20 , 0x00 (For MS5xx )
Offline Hegypt
  • Country: eg
« Reply #233 on: January 19, 2024, 01:19:55 am »
Lexmark, konica ,toshiba and ricoh . Full esp8266 code  resetter
Hani.3dwy@gmail.com
