I've been doing some Peltier module testing using a testing rig I built that includes a circuit to control power to the Peltier module and another to control power to a heating circuit that consists of a couple 5 ohm 10W power resistors. The rig is driven by a Teensy 3.6 micro-controller that's limited to 3.3V so between the P-channel MOSFETS I'm using to do the final drive I have an NPN transistor for each circuit to isolate the Teensy 3.6 from the 12-16V the MOSFETS see as well as provide more current to drive the gates of the MOSFETS. I'm using a 1.5kohm pull-up resistor at the gate so that when the NPN output is off the gate is pulled high turning off the MOSFET.
While running I noticed the power values at the various duty-cycle setpoints appeared to be high so I hooked up the scope and confirmed the MOSFET output duty-cycle to be about 2.4% greater than intended and about 2% higher than the duty-cycle from the Teensy. The on-time slope was within 1uS but the off-time was more like 13.5uS. I figured that the gate capacitance was the likely culprit and when I added a second 1.5kohm resistor in parallel with the original pull-up, effectively halving the value, the off-time dropped to about 6.8uS. This certainly pointed to the gate capacitance as the problem. On turn on the NPN transistor appears more than capable of charging the gate capacitor within about 1uS but the 1.5kohm resistor is too limiting to shut it off as quickly. A 100ohm resistor would do the trick as far as speed is concerned, but it would need to handle about 2.5W -- not practical.
OK, with that out of the way the question posed in the title comes to mind -- namely, do low RdsON MOSFETS have higher gate capacitance as a rule and if so is that do to the gate area being greater as a means of lowering the RdsON value? My brief perusing of a few data sheets seem to suggest that MOSFETS with low RdsON do in fact tend to have higher gate capacitance than do MOSFETS with higher RdsON values. Again, if this is down to the effective plate area of the gates then this would make sense if low RdsON MOSFETS have larger gate areas.
Now, assuming I have this correct it would appear that low RdsON MOSFETS are a great choice for loads that do not switch ON/OFF very frequently but that for circuits that need to switch frequently, such as a PWM output, that a MOSFET with a somewhat higher RdsON value and lower gate capacitance would be much preferred. In fact, even with a higher RdsON value if the device turns ON/OFF much quicker it could well dissipate less heat than a lower RdsON device that stays in between ON/OFF longer and therefore operates at higher resistance.
The components used were:
NPN = ZTX618
P-Channel = IPB120P04P4L-03
The Ciss of the MOSFET is listed as typically 11380pF with a max of 15000pF which is much higher than an IRF4905PbF whos Ciss is listed as typically 3400pF. Interestingly, the 6.8uS turn-off of the IPB120P04P4L-03 when using a pull-up of 750ohm results in a single time constant of 6uS so I calculate the gate capacitance at 8000pF -- lower than the specifications.
Brian
