Hey guys! I have project where I have to measure voltage from a 40VDC (max) source using an acquisition device that has an input limit of 5V. So far, the only viable solution I've come up with is the attached image, a voltage divider and a buffer for isolation. But
I want to know if there's any other solution that I can build (so, no DC-to-DC converters).
Thank you in advance
PS: I know this is a good and easy solution, but I'd like to know the alternatives, if there's any. It's just me being stubborn for the sake of learning
