Author Topic: What components do I need to power a ceramic heating element on the go?  (Read 1958 times)
Offline crunchercrunchTopic starter
Hello all.
I've got one of these:
http://www.ebay.com/itm/12V-150W-AC-DC-PTC-heating-element-heater-Electric-heater-ceramic-Thermostatic-/261397773653?
and I want to bring it around with me. What options do I have to power it so I can use it whenever and wherever I go?
Offline Mr.B
Re: What components do I need to power a ceramic heating element on the go?
« Reply #1 on: February 19, 2015, 12:10:53 am »
A trampers frame pack and a couple of car batteries...  >:D
Offline ajb
« Reply #2 on: February 19, 2015, 12:18:20 am »
Taking the eBay specs at face value, you'd need a power source capable of providing 12V at 12.5A for as long as you want to run it. If you want to run it for an hour, you'll need a battery with a capacity of at least 150 watt-hours. For comparison, a typical 18V Li power tool battery is 50-60 Wh.
« Reply #3 on: February 19, 2015, 12:20:53 am »
Thanks guys. It really seems like a giant battery will be what I'll need. Any tips for safely handling connecting the terminals?
It seems the standard voltage for car batteries is 12V. If my heater was at a higher voltage (for example, just say, 48V), is my cheapest option to just tie the batteries together in series? Or are there other options for higher voltages?
« Last Edit: February 19, 2015, 12:22:33 am by crunchercrunch »
Offline Whales
    • Halestrom
« Reply #4 on: February 19, 2015, 12:31:13 am »
Running it at a lower voltage will reduce power draw and heat output but it will still work fine.  If it says something like 48V then that's what the other ratings (eg wattage) are for.
For this power level connecting batteries in series is probably your best option.  A 'boost' converter to get higher voltages is a great solution in a lot of situations, but if you need to be delivering more than several amps it's probably quite costly.
