The first two photos show a cordless driver battery, before and after a modest top-up charge. Fortunately, I had moved it to a safe place. I had bodged five 2.8Ah pouch cells from a RC drone battery, matched for exact voltage but not protected by a BMC.
The next pic shows a 20+Ah, 11.1V pack, 3S-10P. I just scored this, and want to use it for a high drain load.
It has but a modest BMC, next pic. The two 4663 mosfets in series opposition are only good for a few (<5)A, as also so are the pcb tracks and lead wires fitted. I stripped the outer shrink plastic jacket to take pics.
The 10P 18650's should be good for some 40A. The inter cell connections are properly welded.
I propose to fit an external mosfet disconnect switch, to be tripped by the BMC itself if it detects an abnormal condition. A 12V coil relay can also be used, if the coil is not energized in standby condition. That way, the BMC will not see the high drain current. Charging at <5A can still be done via the BMC. All wiring will be made appropriate. A 40A auto fuse may be enough, but I am looking at better current limiting/ tripping.
Any further safety issues? Please explain with reasoning. Thanks for your time.
Please overlook the wrong order of attachments.
