Just as some background, the design is part of a university project looking at using a pre-existing domestic hot water cylinder as an energy storage unit with the intention of decreasing a households annual power bill by up to $550-700 NZD. In New Zealand, hot water usage accounts for 35% of a typical domestic households annual power bill.
I understand the marginal benefits of having a DC-DC converter for mppt of the PV panels. In fact, it will only provide up to 15% increase in efficiency.Still, an additional 15% in efficiency can mean a saving of $75-$112.5 NZD annually.
An additional reason why PV hot water is being investigated is that the alternative,direct solar hot water, requires the expertise of an experienced plumber for installation, and the systems are often prone to failure. As my professor said, he knows off by heart the number for his plumber.
The aim is to come up with a design that is efficient,complies with safety requirements, and (hopefully) can be bundled up as a complete package for any DIY enthusiast to purchase and install themselves without the need for a sparky.
You probably want to specify how you would like the converter to behave when there isn't sufficient power from the panel.
the rest is easy.
I'm not quite sure what you mean by how would I like the converter to behave, can you please explain in a little more detail. I do hope the rest will be easy.
Thanks for your comments.
Josh
