Author Topic: Limit switches and reed switches for use in vacuum  (Read 2506 times)
Offline GasperSBTopic starter
« on: January 16, 2020, 04:07:05 pm »
Hello everyone!
I'm designing a test setup based on requirements from our physics department. The major part of the test setup is a linear rail with a slide. In order to safely perform required tests I need to add a limit switch at each end of the rail. Tests are going to be performed inside a vacuum chamber.
I'm interested if anyone here knows any suppliers or manufacturers that provide limit or reed switches for vacuum environment. Preferably in small form factor.
Best regards,
Gasper
EDIT: Vacuum level: ~ 10^-7 Pa (10^-9 Torr)
« Last Edit: January 16, 2020, 08:09:44 pm by GasperSB »
Online Kleinstein
Re: Limit switches and reed switches for use in vacuum
« Reply #1 on: January 16, 2020, 04:27:14 pm »
The glass encapsulated reed contacts should be no problem with vacuum. For other type is depends on the vacuum grade - down to some mPa should be OK with most types, better vacuum could be tricky, especially if a bake out is used.
Beside reed switches hall sensors could be an option too, as they can be smaller. It just need the power part outside.
Offline RoGeorge
« Reply #2 on: January 16, 2020, 04:35:00 pm »
If the vacuum chamber is just a glass bell, or of it has a visiting window, maybe an optical switch can be put in place, where both the emitter and the receiver of the light ray(s) can stay outside.
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #3 on: January 16, 2020, 05:16:02 pm »
Is the vacuum sufficiently good that you need to worry about out-gassing from components? Operating in vacuum is quite different from not messing up an experiment that requires a very high vacuum.
Offline grifftech
    • youtube channel
« Reply #4 on: January 16, 2020, 06:10:25 pm »
to simplify: how strong is the suck
Offline i_am_fubar
« Reply #5 on: January 16, 2020, 08:03:06 pm »
https://shop.allectra.com/products/363-SWITCH-2
They do a UHV and bakeout rated switch. Pricey though.
Other option is peek block with spring plungers crimped on.
As others say, depend on levels.
The following users thanked this post: GasperSB
Offline i_am_fubar
« Reply #6 on: January 16, 2020, 08:04:38 pm »
Would it be an option to use a mechanical feedthrough? Brings switches out of vacuum.
« Reply #7 on: January 16, 2020, 08:07:44 pm »
Science experiments will be done in a high vacuum, close to ultra-high vacuum. ~ 10^-7 Pa (10^-9 Torr). So, yes I need to consider outgassing.
Offline i_am_fubar
« Reply #8 on: January 16, 2020, 08:10:40 pm »
And bake out to hit those in any reasonable time. Just be aware of your material selection (PEEK, PTFE, ceramics and many common metals).
Do you have UHV design experience?
« Reply #9 on: January 16, 2020, 08:25:00 pm »
Unfortunately, there is no space for a mechanical feedthrough.
Not much, pretty new on the job... Though, I knew I need to be careful with material selection. The vacuum chamber design is on the mechanical department, they just asked me to help them select limit switches and electrical feedthroughs.
Thought to ask on this forum to see if anybody has a goto manufacturer for vacuum compatible electrical components.
Offline RoGeorge
« Reply #10 on: January 16, 2020, 08:37:32 pm »
If you are on a very tight budget, auto spark-plugs can be used as electrical feed-through.
Offline i_am_fubar
« Reply #11 on: January 16, 2020, 08:46:02 pm »
Allectra & hositrad for the UK and europe. but pretty much that switch I linked was all I found when I was looking for my application. Most vac specialists sell the same one.
Couple of gold plated spring terminals is cheaper option. Take care with handling, gloves are a must to keep clean.
Not tried reed switches, but glass with compatible leads should be fine. Crimp or screw, don't solder.
Sorted the feedthroughs already?
Offline Doctorandus_P
« Reply #12 on: January 16, 2020, 08:54:35 pm »
If you're thinking reed switches, then you're thinking magnetics.
Which opens up the road to HALL sensors.
If you want them small, they can be bought in SOT23 packages.
Offline i_am_fubar
« Reply #13 on: January 16, 2020, 09:02:05 pm »
Be wary of any conventional chips. PCBs become a huge issue with solder, silicone, out gassing... Etc
You can get hal effect transducers for UHV, but they are crazy expensive and need external drivers.
« Reply #14 on: January 16, 2020, 09:33:45 pm »
No, I haven't selected feedthroughs yet. I first want to define all electrical components and then based on that decide what is needed and what is the most suitable.
Yeah, I thought about reed switches because some already have a vacuum inside the glass tube, therefore, the leads could already be vacuum compatible.
We have a moderate budget for this project. But I would definitely like to stay away from super expensive components.
Offline i_am_fubar
« Reply #15 on: January 16, 2020, 09:59:23 pm »
Are stray magnetic fields an issue? Is this electron / ion beam based experiment?
Online TimFox
« Reply #16 on: January 16, 2020, 10:17:31 pm »
Also, for 10-9 Torr, you will need bakeout.  The solid-state Hall effect switch and permanent magnets may limit the bake out temperature.
« Reply #17 on: January 17, 2020, 02:29:50 pm »
@i_am_fubar nop, stray magnetic fields shouldn't be a problem...
Online Kleinstein
« Reply #18 on: January 17, 2020, 04:11:11 pm »
There is still the option to use a direct mechanical contract - kind of build your own switch, especially if the switch is for low power only.
A mechanical feed through is difficult at that vacuum level anyway.
Offline i_am_fubar
« Reply #19 on: January 17, 2020, 05:25:51 pm »
Bellow feedthroughs are good down to -10. But pretty costly.
And stray magnetics kill spot size on low energy charges, even if fat away. Magents in the chamber could magnetise lower grade stainless and be a problem in the future. Just be mindful and if you do go down the reed switch route, use lowest strength you can get away with.
Seconded the DIY route. Will try and get some sneaky pics of our solution on Monday.
