few comments on this one:
are these low emf binding posts? I do not know this brand, would be interested to know, maybe they are a lower cost alternative to the pomona ones. they should be low emf, to use the 1ppm/0.01% accuracy.
also, any reason why these were not made 4-wire. at the resistances and tolerances used, that would be desirable.
thirdly, does anyone have experience with resistor aging. vishay foil with low aging rates (<1ppm/year) are all oil filled. I built a set of vishay foil standards, using 0,05ppm/k types (at room temperature), but except for the 10k type, i did not use hermetic ones due to cost. so i was wondering if anybody has experience with aging (the non-hermetic ones are said to age/change by about 20ppm over a year, depending on humidity; vishay says that). idea would be conformal coating (after baking) or putting them in a case filled with silicone oil.
what puzzles me is, I spend a lot of money calibrating them, and then they change by as much as 20ppm. I use them for some precision measurements, so 20ppm is pretty high in that respect.
