First, thank you all for your replies.
I need to measure the power consumption of micros (SoC usually). Usually the supplied voltage is around 3.3V, but the current can range from a few hundreds of mA to a fraction of the uA, depending on the micro.
As such I have to use a sensing resistor, paired with an instrumentation amplifier (e.g. AD621). Since the output of the IA goes straight to an oscilloscope, I have to shield noise pick ups while avoiding ground loops.
On purpose, I'd like to put together a power supply to power up the IA and, if possible, the micro controller as well. Thus I am avoiding switching converters, to keep the design on the simple side and to limit the generated noise.
Although I thought about putting a resistor on the DC side towards the earth, I wonder if noise can crawl up through the ground line and mess with the sensing. The same goes with everything comes to my mind.
If possible, since I don't mean to build anything fancy such as a bench power supply, but rather a specialized tool, I'd like to avoid a battery powered solution and it would be great to keep the budget low, thus I am asking the forum.
