I found this schematic floating about on the web, and decided to compare it against the PCB of my recent fleabay purchase.
I verified that pin 4 of the UC3823N is not connected to ground, as noted
here.On my PCB, capacitor C5 was omitted and the integrator C3 had a slightly different value.
The schematic omitted the EMI filter. It also omitted the green LED that illuminates when the unit is switched on, the anode of which connects to U2 pin 12 via a 330 Ohm resistor.
