I felt your pain a while ago, it gets somewhat better eventually, and not because you move to a less stressful career like hostage negotiation.
I think a large portion of the problem as you describe it is that you are expected to either be closely working with a vendor representative, or know somebody at your company who already knows this stuff. It's certainly doable on your own (as that's how I learned all of it), but unless you have a resource you can quickly ping, it takes a ton of time.
Edit: The one place I have seen concessions made to those who don't fit those characteristics is in in the provision of a fully configured system matching an eval kit or other reference design the you aren't expected to need to adjust. But once you get outside that, it's pretty quickly into the deep end.
I no longer know links to most of the resources I used to learn about device trees, but there are some decent talks about devices trees and the promise they hold, and somewhat how they work, out there on the internet. Just remember as you delve into the older talks, that some of the rosy outlooks for how device trees are going to solve all your problems and make breakfast in the morning really didn't pan out that way in the real world. Especially the theoretical one ideal device tree that perfectly describes the hardware can be flashed onto the hardware and never changes, even as kernel versions change or you go between vendor release branches or the mainline kernel tree*. I can't speak to the consistency of the SAM A5 parts and the various kernel trees out there for them, as I have never used them.
I usually get device tree information from several sources:
- Random google searches and forum posts
- The bindings documentation mentioned by langwadt
- Other kernel documentation for the subsystems that's not specifically for device trees
- The code for the driver I am trying to use. Look in the foo_probe function and sometimes you can have an easier time of figuring out what an under-documented driver takes for arguments
- Other similar looking boards whose device tree source files are easily made public, say as part of the device tree source folder in the kernel
For your specific point about not being able to to find the full device tree files, the device trees usually include** references to other files containing more generic information and description.
As some examples let's take two sam a5 boards "supported" by the mainline linux kernel branch, the sama5d4_xplained board from microchip, and what looks to be a 3rd party som (Aries/DENX MA5D4) and the eval kit (Aries/DENX MA5D4EVK). Nothing specific about my choices other than being the first things to catch my eye looking through the listing of device trees.
If you look at the MA5D4EVK (
https://elixir.bootlin.com/linux/latest/source/arch/arm/boot/dts/at91-sama5d4_ma5d4evk.dts) you will see it's fairly short and filled with references not directly mentioned in the file, but at the top it includes at91-sama5d4_ma5d4.dtsi (
https://elixir.bootlin.com/linux/latest/source/arch/arm/boot/dts/at91-sama5d4_ma5d4.dtsi). This chained series of course lets the common features of the MA5D4 som be described in one place, while supposedly features specific to the EVK can be only listed in a file for the EVK. Now you may be saying, I looked at the MA5D4 som files you linked and it's still missing stuff. That's because it includes the sama5d4.dtsi (
https://elixir.bootlin.com/linux/latest/source/arch/arm/boot/dts/sama5d4.dtsi), which actually describes the peripheral set available to *all* designs that use the SAMA5D4 chip. If we then go look at the official sama5d4 xplained board (
https://elixir.bootlin.com/linux/latest/source/arch/arm/boot/dts/at91-sama5d4_xplained.dts) you can see it includes the same sama5d4.dtsi as the som above uses, since it is based on the same chip. Some chips go even further and have a family common include file that each chip's include file modifies with the unique features.
While you may be using a vendor provided kernel release, it is almost certain that they provided most of these files in similar places in their folder structure.
You may also be able to find a support forum that you may find people discussing getting a peripheral working that is useful to you. Microchip likely hosts one.
Hopefully this helps point you on the right track, and isn't just a repeat of things you already know. I am no expert on this, but I muddle along enough that the people who pay my salary seem to be happy.
* Yes technically most of this is usually the vendor's fault, but it's still something to be aware of when you go out looking for help or snippets solving a problem.
** Unless its a specific device tree overlay file, which I usually see in the hobby community where the external hardware cannot be fully determined at build time and instead depends on what the user has to connect. They simply have references, and expect the kernel to fill things in at run time.
