Author Topic: Lion Battery Packs, BMS's Chargers...  (Read 680 times)
Offline mrpacketheadTopic starter
  • D Size Cell
« on: November 20, 2023, 12:36:38 am »
 Hello Folks, who know stuff i dont.
I'm got a need to build 2 Lithium Ion Battery Packs using 18650 battery packs.   One will be 10s, 5p, ( 36V nominal ).  I want to use this to power up my Makita Lawnmower, which flattens the LXT batterys quite quickly and i need ~10 to get through my lawn.    I'm building it with a JK BMS ( BD4a17S4P ), that is appropriately rated for the job.    I have a very low capacity charger, but it will take 3 days to charge it up!
The other will be a 12s, 4p,  ( 44V nominal ) which i want to use for a heavy lift ( well, 6kg ) drone.   Have not yet started this, and dont' have a BMS for it.
What i'm wondering about is a charger..   I have several Meanwell RSP-48-2400 PowerSupplies, which can be adjusted up to around 56V, and down quite a long way..
Does anyone know of a ready made DC input charge controller that might be suitable?
Offline p.larner
Re: Lion Battery Packs, BMS's Chargers...
« Reply #1 on: November 20, 2023, 05:20:33 am »
look for ebike chargers on aliexpress,i just got a 54.6v 3a unit for 12 pounds delivered.
Offline XxMandragoraxX
  • Country: pt
« Reply #2 on: January 14, 2025, 07:16:18 am »
Hellow mrpackethead.
I saw you were making battery packs for applications that need a lot of power. You can’t use standard batteries because you need a high C-rate for those, especially for the Makita. I know the post is old, but I’m also interested in making efficient BMS, like u. Did you manage to get any info in the end?
