I'm working on a design that uses a protection IC for a single lithium cell. When looking at some cheap chinese protection IC's I came across the app circuit in the datasheet for the fs312f-g:
Something immediately stuck out to me: the current sense pin (cs) is connected with a 1K resistor to BATT-. This doesn't make sense to me, from my understanding a current sense pin should measure the voltage across a shunt resistor wired in series between the negative terminal of the battery and the source of M1. This would also make more sense if you look at pin CS in the functional diagram of the chip.
Another weird thing is that if the charger voltage across BATT+ and BATT- is above around 4.3v the mosfet pair will isolate the battery from the charger since there is an overvoltage situation. Normally the IC will monitor the charger voltage until it has dropped to the release voltage. But how is the chip supposed to measure this if it doesn't have a reference of BATT- anymore since the mosfet pair isolated this pin from the chip? (via CS somehow?).
Apparently there are more protection IC's with similar app circuits:
https://www.digikey.com/en/maker/blogs/lithium-ion-cell-protectionI have worked with an MM3722 protection chip from Mitsumi before which has the following app circuit:
This makes a lot more sense to me: pin CS measures the voltage across shunt resistor Rsns and pin V- is used as a reference for the release voltage.
Why does the fs312f-g not work like this?
