Hello, probably most of the people that have designed LLC converter had faced the problem I will describe.
When the LLC converter is designed with center tapped transformer and integrated inductance things come critical.
First of all both leakage inductance ( shorted secondary windings ) must be equal as possible. Otherwise large current disbalance will occur on secondary switches.
Another critical part is the parasitic secondary inductance that is coming from the layout. That parasitic inductance could create large current disbalance on secondary switches.
So the question is related with the layout. Drain track layout is perfectly matched on both transistors, but how do you match and should you, source track layout.
Here I have to mention first revision layout I didn't have matched drain paths and one of the switches raised its temperature with 30 degrees more than the other ( current disbalance ), With the second revision I populated one PCB and it works fine, but than I populated one more and it seems there is disbalance cause one of the switches temperature is larger than the other.
