Okay guys, so I've been working on this project and I found an unknown interference on the circuit.
Here's what happened :
1. I me an astable circuit from 555.
2. Then I connected the pin 3 output to the gate of a mosfet to turn led on and of ( the drain has12v and connected to the leds. The source pin connected to ground
So far so good, the leds turn on and off
3. Then i connected the gate of an scr to the pin3 output of 555.
4. The anode connected to a fan and 12v, the cathode connected to the ground.
Now when I connected the scr, okay thefan turns on constantly because of the scr. But the leds also turned on constantly. And when I checked It with my multimeter, the output ofpin 3 change to a constant 5 v ( before i connected the scr Gate to pin 3, the pin was emitting square wave)
What's happening in here guys?
? Help.....
