Author Topic: LM2596 Controllable Buck Converter Switching Noise on Signal  (Read 3851 times)
Offline syntax333Topic starter
Hi, I am using LM2596 Power Module to convert 18V to 10V for my application.
However, signal that I am working on has spikes with constant frequency. I checked everything on circuit and found out my cheap power module has the same switching frequency.
In attachment you can see both my signal and switching of LM2596.
Power output of LM2596 is connected do decoupling capacitors of the ICs which outputs this signal.
Is there a way to get rid of this noise? or better converter suggestion which has better characteristics?
Thank you.
« Last Edit: May 01, 2019, 04:23:09 pm by syntax333 »
Offline madires
  • A qualified hobbyist ;)
Re: LM2596 Controllable Buck Converter Switching Noise on Signal
« Reply #1 on: May 01, 2019, 04:33:55 pm »
The LM2596 has a switching frequency of 150kHz. Maybe a poor counterfeit?
« Reply #2 on: May 01, 2019, 04:43:41 pm »
Probably :( I was thinking plugging a linear L7809CV regulator to output of power module.
Do you think this will help the situation?
Can you suggest other regulators with better performance?
Online wraper
  • Country: lv
« Reply #3 on: May 01, 2019, 04:44:16 pm »
Not maybe but certainly counterfeit. 99% of these modules on ebay and aliexpress use counterfeit IC.
Offline mariush
« Reply #4 on: May 01, 2019, 04:47:36 pm »
It's probably a clone of LM2576 ... which in theory is supposed to be a 52 kHz switching regulator.
The following users thanked this post: perieanuo
« Reply #5 on: May 01, 2019, 05:24:16 pm »
So do you think signal disturbance is due to power supply?
Offline Le_Bassiste
« Reply #6 on: May 01, 2019, 05:44:42 pm »
can speak for waveform in 2nd picture only. perfectly fine for a buck converter that's running under lighter load than it was designed for.
this is called "discontinuous mode", because the inductor is "running out of steam"  during the free-wheeling phase, and then resonating with the circuit's stray capacitances.
if fast step response is not an issue in your circuit, you can basically increase the inductance to a value such that the inductor current still hasn't fully vanished at the beginning of the next ON phase. then the inductor current is never going back to zero, and the buck converter will run in "continuous mode". in continuous mode, the voltage in the 2nd picture will change to a clean (if pcb layout is good) square wave.
An assertion ending with a question mark is a brain fart.
« Reply #7 on: May 03, 2019, 11:02:16 pm »
Is this ringing on signal normal for a buck converter or is this due to power module being a counterfeit?
Offline ptricks
« Reply #8 on: May 04, 2019, 03:09:10 pm »
My experience has been that the cheap power modules , the 5 for $10 ones sometimes ship with open inductor vs the shielded type and you can see all sorts of noise in the outputs from it depending on load.
You can try putting an LC filter on the output and see if that helps.
Offline madires
« Reply #9 on: May 04, 2019, 03:40:23 pm »
Switching power causes ringing. The amount of ringing depends on several factors, for example the buck converter's operation mode, load, the components chosen and so on. A poorly designed buck converter can make things worse (controller IC and complete circuit). ptricks' suggestion to add an LC filter is the standard way to reduce switching noise.
Offline Le_Bassiste
« Reply #10 on: May 05, 2019, 06:23:57 am »
no, this is not indicative of a counterfeit part. its telling you that the buck is running in discontinuous mode (DCM).
of course, your power module may still be consisting of counterfeit parts, though  :-//
