I searched the forum, but did not found a similar issues as mine, so I post it as a new topic.
I work on a project where a Raspberry PI and an Arduino will 'speak' together. Since the project will be powered from 5 Akkus, each having 3800mAh, and also because the total consumption of the project can go up to 1A, I use a LM338T with an attached heatsink. Yes, I am aware that the voltage can go as low as 5.xV and the output of the LM338T can go under 5V when the accus are low, but very likely at the end I will use 6 accus and this will not be a problem anymore.
So I created the circuitry with LM338T, 220Ohm fixed value for R1 and 0-2.2k pot for R2 (I want to be able to fine adjust the voltage). I also added a 10uF Cap on the output (but not yet a 0.1uF ceramic on the input, I wait for my package with 0.1uF caps).
Now comes the problem:
1. If I don't have a load on the circuitry, then the voltage of the LM338T is almost the same with the input voltage ( 0.4V-0.6V less) - that may be ok, since a minimal 3.5mA load is specified in the datasheet
2. I add a 10 Ohm 20W resistor as a load. Now my power supply (that provides the input for the LM338T shows around 400mA, and the output voltage is 7.5V). The output voltage from LM338T is 5V (with the R2 set to a value of aprox. 660 Ohm). Actually, I was expected 500mA since 5V are dissipated in the resistor and according to the Ohm Law we have 5V = 10 Ohm * I, so I = 0.5A (on, this is an approximation since the resistor is actually 9.4Ohm, but still...the difference is big).
3. This is my real problem: I remove now the resistor and the output voltage of the LM338T drops to 3.9V and stays there until I connect back the 10 Ohm resistor. If I connect a small load (like an LED set to 10mA current) in place of the big resistor, then the voltage stays at 3.9V, but if I change the output of the power supply from 7.5V to 6V then the voltage output of the LM338T goes to 5V (which is the normal value). Now I can set back the voltage on the power supply to 7.5V and the voltage on the output stays at the normal value of 5V. Also if I stop the power supply when the voltage was 3.9V and the 10mA led was connected, then when I turn it back the voltage goes to the value that it should be, that is 5V.
Please note that all the tests were made using a linear power supply set to 7.5V.
Do I miss something or this is behavior is just strange... I have 2 pieces of LM338T and both acts the same, so can't be a defect in both...or ?
The diagram to wire the LM338T I used is exactly the one from the datasheet (the simple one with two resistors and 10uF cap on the output).
Thanks in advance for your time and answers.
Mircea.
