Back in 2004 I stated making an active load for testing power supplies. Never did get it finished. Dragged it out tonight for a look-see. The mosfets are ST Y32NB50. 500V 34A 0.11 ohm TO-247 max. They were a bit of a dog for SMPS PFC usage so I ended up getting a bunch of them free. Each source lead has a pair of paralleled 4R7 2W resistors. 15K gate resistors to make it very docile. I'll run a 1K resistor from each of the sources and join them together and use that common point to measure the current and send it back to an opamp. Each heatsink should be good for 300W continuous, lots more for short bursts. Each mosfet has a rating of 450W @ 25 deg C, derate 3.6 W per deg C.
