Author Topic: Free Mosfet Model Maker Excel  (Read 625 times)
Offline rbola35618Topic starter
« on: November 19, 2024, 09:59:44 pm »
I present a Microsoft Excel spreadsheet that can be used to make a SPICE model from the part's datasheet. In a previous video, I used Mathcad to make my MOSFET SPICE model, however, I no longer have access to Mathcad and Excel is a great alternative. I show how to use the ID vs VDS family of curve to extract the DC characteristic and the parasitic capacitance to get the AC characteristic and then show how to verify with SPICE. Please keep in mind that this is a first order model. I have successfully used this procedure to model devices that have no SPICE model and have gotten good results. If you find this video useful, please subscribe and share. Request for the Excel spreadsheet can be sent to rbola35618@aol.com.
I have attached the file. Please change the suffix from .TXT to .xlsm
« Last Edit: November 21, 2024, 03:31:22 pm by rbola35618 »
Offline Benta
Re: Mosfet Model Maker Excel
« Reply #1 on: November 19, 2024, 10:22:03 pm »
Did you try GNU Octave?
It's a free, open-source alternative to MatLab. Not as easy to use as MathCad, but prolly easier than Excel.
Online Zero999
  • 0999
Re: Free Mosfet Model Maker Excel
« Reply #2 on: November 21, 2024, 09:22:36 am »
I suggest you consider removing your email, as it might attract spam.
Is there any reason why you don't want to post it as an attachment? Either zip it, or save it as ods and you can upload it by clicking on  Attachments and other options.
« Reply #3 on: November 21, 2024, 03:32:51 pm »
I tried to upload the excel file but it won't allow excell file to be loaded. I changed the extension to .TXT. Hopefuly this will work if you rename the extension back to .xslm
The following users thanked this post: Zero999
Online Zero999
  • 0999
« Reply #4 on: November 21, 2024, 04:35:26 pm »
That's because the forum doesn't support files with the extension .xlsm
An alternative to renaming it is to create a zip file, using an archiving utility, such as 7-Zip or the one built in to Windows, which saves the person downloading it from renaming it.
« Last Edit: November 21, 2024, 09:42:43 pm by Zero999 »
The following users thanked this post: rbola35618
« Reply #5 on: November 21, 2024, 08:17:06 pm »
Thank you!!!!!!
Online TimFox
« Reply #6 on: November 21, 2024, 08:45:18 pm »
The macro-enabled version of Excel files is .xlsm, not .xslm
https://www.omnisecu.com/excel/basics/difference-between-xls-xlsx-xlsm-file-formats.php
Online Zero999
  • 0999
« Reply #7 on: November 21, 2024, 09:44:13 pm »
It was probably a typo and I don't know any better, since I'm not an MS Office user. I did find it odd that it didn't automaticaly open with LibreOffice on Linux when I clicked on it, but that sort of thing is common.
« Last Edit: November 22, 2024, 08:05:46 am by Zero999 »
