I have a need to use series of electrical connectors between a load cell and an ADC board. I'm concerned about the effects of the connections on the signal. This is for a machine that is expected to be maintenance-free for about ten years.
I purchase the load cell. It comes with a shielded, four 30 AWG conductor cable. The conductors are seven strand tin plated copper. I cut the cable to about 200mm in length. I need to connect this cable to a high flex cable that will run through a (300mm long) Igus chain track. I need a connector there. This will be connected only once, during assembly. I have previously spliced and soldered the wires together but I want to get away from this as it's way too much work and probably not very reliable.
Within the Igus track I have room for five 'high flex' 30 awg single conductor wires, four for the Wheatstone bridge and one for the shield. The shield will no longer be braided but I'm not worried about it as the entire system is contained within a thick steel tube that is grounded. My ADC board is at the end of Igus track, bolted to the exterior of the steel tube. I need to connect the Wheatstone bridge wires to my ADC board. I want to use use screw terminals, headers, or a connector on my board. I have previously soldered the wires directly to the board. I want get away from this as I don't believe it's reliable. The board is my design so I can use whatever connection I want.
The cycle time for the machine is typically a few seconds, at most it's a few minutes. I am able to 'zero' the bridge between cycles. So I'm not too concerned about short term drift. I am, however, concerned about electrical noise. I'm striving for 1 part in 10,000 noise free resolution. I use a delta sigma ADC sampling at 1kHz. This has shown to work well with soldered connections.
Usually I try to use gold contacts for low voltage signal connections. The only connectors for 30 awg wire I can find, with gold contacts, use an IDC connection to the wire. I feel as though a crimp connection would be better. The wire to connector interface is tin plated copper wire with a tin plated contact. Is this okay long term? How can I connect the wires to my ADC board? Would a screw terminal with tin contact work? Are there any gold contact screw terminals out there? Are there any references out there that might help me to understand low-voltage signal connections?
Thanks in advance for any help.
