Electronics => Projects, Designs, and Technical Stuff => Topic started by: Alex QW on March 14, 2023, 05:57:55 am
Title: load circuit
Post by: Alex QW on March 14, 2023, 05:57:55 am
Hi all,
May I know how this TTL load circuit work as shown in the below diagram?
Note that: 1)the red arrow means the microcontroller control signal (1,2)
                2) Is the TTL output pin (3,4)
The circuit is in this link: https://forum.allaboutcircuits.com/threads/ttl-load-circuit.192516/
Thank you.
Best Regards
Alex.
Title: Re: load circuit
Post by: Terry Bites on March 14, 2023, 09:50:31 pm
Erm. I'm not registering with your website.
You didn't give out any information on your circuit there either!
A TTL load is an equivalent circuit of a TTL gate input.
Have a look at the TTL wiki page.
see www.interfacebus.com/Glossary-of-Terms-TTL-Load-Circuits.html (http://www.interfacebus.com/Glossary-of-Terms-TTL-Load-Circuits.html)
Post by: Alex QW on March 15, 2023, 01:23:01 am
May I know why they use a lot of diodes in the circuit?
Post by: Kim Christensen on March 15, 2023, 04:30:48 am
Attach the picture of your circuit here. Most people can't see it on allaboutcircuits.com since we don't have an account.
Post by: Alex QW on March 15, 2023, 06:09:37 am
This is the circuit diagram
Sorry for any inconvenience as I just joint this forum not so familiar with this feature
Post by: Terry Bites on March 15, 2023, 11:41:10 am
The bias resistors set up a current (1.2mA) in the diodes going to ground- this sets VIL for the equivalent gate input plus a diode drop. You then subtract a diode drop ((D604)  from this voltage.
This sets the lower threshold to a bit over VIL.
Post by: Alex QW on March 23, 2023, 01:14:19 am
how to know that the bias resistors set up a current (1.2mA)?
