Author Topic: Sharing a current shunt?  (Read 1892 times)
Offline ThingsTopic starter
  • Laser Geek
    • NQLasers
« on: December 10, 2012, 03:01:12 pm »
Hey guys,
I'm working on an electric scooter project, and seeing as it'll use LiPo packs (And lots of them!), I'm taking protection very seriously. I have found a battery protection/monitoring IC from TI that fits my needs perfectly.
However, on this same board I also want a uC, to do various things like current, speed, temp readouts etc.
So what I'm wondering, is the battery monitoring IC has inputs for a current shunt, which it can monitor and shut off the discharge FET, but I also want to be able to give a current readout on a LCD from the uC.
Is there any accurate way I could share readings from a current shunt between both devices? 2 shunts in series possibly, one for each device?
Cheers,
Dan
Offline grenert
Re: Sharing a current shunt?
« Reply #1 on: December 10, 2012, 03:54:08 pm »
Since the measurement of a current shunt is voltage, as long as your voltage measuring device is reasonably high impedance you should not have a problem.
  • Laser Geek
    • NQLasers
« Reply #2 on: December 10, 2012, 04:10:09 pm »
Oddly enough neither chips seem to specify input impedance.
Offline c4757p
  • adieu
« Reply #3 on: December 10, 2012, 05:23:42 pm »
Measure it. Ohm's law is your friend.
Offline Neilm
« Reply #4 on: December 10, 2012, 05:28:25 pm »
Some of the battery monitor chips TI do can report the current value to a supervisor MCU. If you want to share the current shunt there should be no problem provided you have a high impedance. If you are not sure, you could always use an op-amp to buffer it.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
