Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Is protection needed for the enable pin?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Is protection needed for the enable pin? (Read 594 times)
mrburnzie
Regular Contributor
Country:
on:
March 13, 2023, 05:04:21 pm »
I'm using this (
https://www.digikey.com/en/products/detail/c-k/JS202011JAQN/6137629
) switch to control an ideal diode controllers enable pin (
https://www.analog.com/media/en/technical-documentation/data-sheets/max16171.pdf
Is there a need to protect that enable pin with a TVS? My first answer would be yes, as the switch can discharge and leads directly into the enable pin.
Logged
"Talk is cheap, show me the code"
Anyone need of freelance software/hardware developer, hit me up!
wraper
Supporter
Country:
Re: Is protection needed for the enable pin?
Reply #1 on:
March 13, 2023, 05:12:02 pm »
Depends on if it's directly accessible from the outside or there is some sort of plastic knob which makes it almost impossible for ESD to find a path inside the switch. Then what level of protection/reliability is needed. IMHO no ESD protection is needed in 95% of cases. But strange part is why would you need to control EN pin directly from the switch.
Last Edit: March 13, 2023, 05:13:51 pm by wraper
Logged
mrburnzie
Regular Contributor
Country:
Reply #2 on:
March 13, 2023, 08:45:41 pm »
I don't want a beefy big switch for the powersupply, but more of a simple power button. Thus, disabling the ideal diode of conducting.
Is it just easier to do a beefy switch? The powersupply is at 12V around 4A ~50W.
Logged
mrburnzie
Regular Contributor
Country:
Reply #3 on:
March 13, 2023, 08:51:24 pm »
Maybe I would actually go for some solutions, where it is a push button and it uses a flip flop or a similar circuit to turn on/off the powersupply (ideal diode)
Logged
wraper
Supporter
Country:
Reply #4 on:
March 13, 2023, 09:33:59 pm »
I don't see this switch as a decent power button, it very tiny and not easy to use. It usually used for things with constrained space and rarely used, like power or mode switch on underside of a computer mouse.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
