Author Topic: Logitech mouse: where is the scroll wheel HID event/report?  (Read 324 times)
Offline sraposoTopic starter
  • Country: br
« on: November 12, 2024, 11:48:00 am »
Hi!
That's a matter related to USB/HID, I believe, not a SoC/MCU-specific.
I am working in a ESP32-S3-base project and I've just faced a weird situation: an USB Logitech mouse, that fully works when connected to a PC, does not send any byte related to scroll wheel. Input report contains only 3 bytes: 1 for buttons (including the scroll wheel switch), other for horizontal movement and the last for vertical direction. None of them present any variation when scroll wheel is spun.
Another mouse, brand Knup, has a 4-byte input report, where the 4th byte is dedicated to the (vertical) scroll wheel movement.
I could not get any (especial) event when scroll wheel is rolled, even considering non-mouse interface, as if this feature was not present.
It's clear there's something particular about Logitech mouse. I'm wondering if mouse driver sends some output report to the mouse in order to instruct it to deliver some data related the the scroll wheel. Only guessing...
Can anybody point me some direction?
Offline Someone
    • send complaints here
Re: Logitech mouse: where is the scroll wheel HID event/report?
« Reply #1 on: November 13, 2024, 01:30:24 am »
Look at the full enumeration tree when it is connected to a computer. Mice and Keyboards these days use multiple "devices" to produce their rich functionality. Some smaller host is not utilising all the endpoints (and/or misses drivers for them).
  • Country: br
« Reply #2 on: November 13, 2024, 11:18:00 am »
Hi!
I had already used MS' USBView and nothing useful was detected.
I used Device Monitoring Studio (free version) to sniff USB packets and I could discover that Logitech mouse has also a forth byte in input report to inform scroll wheel action, like the other mouse! I suppose Logitech mouse driver did some modification.
Below, I transcript USBView report of both mice:
Knup Mouse :
[Port1]  : USB input device
Is Port User Connectable:         yes
Is Port Debug Capable:            no
Companion Port Number:            16
Companion Hub Symbolic Link Name: USB#ROOT_HUB30#4&1ed8c4ae&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
Protocols Supported:
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Device Power State:               PowerDeviceD0
       ---===>Device Information<===---
English product name: "Usb Mouse"
ConnectionStatus:
Current Config Value:              0x01  -> Device Bus Speed: Low
Device Address:                    0x02
Open Pipes:                           1
          ===>Device Descriptor<===
bLength:                           0x12
bDescriptorType:                   0x01
bcdUSB:                          0x0110
bDeviceClass:                      0x00  -> This is an Interface Class Defined Device
bDeviceSubClass:                   0x00
bDeviceProtocol:                   0x00
bMaxPacketSize0:                   0x08 = (8) Bytes
idVendor:                        0x1C4F = Beijing Sigmachip Co., Ltd.
idProduct:                       0x0034
bcdDevice:                       0x0110
iManufacturer:                     0x01
     English (United States)  "SIGMACHIP"
iProduct:                          0x02
     English (United States)  "Usb Mouse"
iSerialNumber:                     0x00
bNumConfigurations:                0x01
          ---===>Open Pipes<===---
          ===>Endpoint Descriptor<===
bLength:                           0x07
bDescriptorType:                   0x05
bEndpointAddress:                  0x81  -> Direction: IN - EndpointID: 1
bmAttributes:                      0x03  -> Interrupt Transfer Type
wMaxPacketSize:                  0x0004
bInterval:                         0x0A
       ---===>Full Configuration Descriptor<===---
          ===>Configuration Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x02
wTotalLength:                    0x0022  -> Validated
bNumInterfaces:                    0x01
bConfigurationValue:               0x01
iConfiguration:                    0x00
bmAttributes:                      0xA0  -> Bus Powered
  -> Remote Wakeup
MaxPower:                          0x32 = 100 mA
          ===>Interface Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x04
bInterfaceNumber:                  0x00
bAlternateSetting:                 0x00
bNumEndpoints:                     0x01
bInterfaceClass:                   0x03  -> HID Interface Class
bInterfaceSubClass:                0x01
bInterfaceProtocol:                0x02
iInterface:                        0x00
          ===>HID Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x21
bcdHID:                          0x0110
bCountryCode:                      0x00
bNumDescriptors:                   0x01
bDescriptorType:                   0x22 (Report Descriptor)
wDescriptorLength:               0x0034
bLength:                           0x07
bInterval:                         0x0A
Logitech mouse:
[Port2]  : USB input device
Companion Port Number:            17
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
English product name: "USB Optical Mouse"
ConnectionStatus:
Device Address:                    0x03
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idVendor:                        0x046D = Logitech Inc.
idProduct:                       0xC077
bcdDevice:                       0x7200
iManufacturer:                     0x01
     English (United States)  "Logitech"
iProduct:                          0x02
     English (United States)  "USB Optical Mouse"
iSerialNumber:                     0x00
bLength:                           0x07
bInterval:                         0x0A
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
wDescriptorLength:               0x002E
bLength:                           0x07
bInterval:                         0x0A
« Last Edit: November 13, 2024, 12:26:45 pm by sraposo »
