That's a common package for hall effect sensors, unless someone recognizes the marking it will be hard to say more than that from the picture. Clearly it needs to be an analog output for measuring current, possibly bipolar if you need to measure current in both directions. From there you will need to do some design work based on the geometry and current range you need. I imagine calibration could be challenging, depending on how consistent and stable the individual sensors are and how accurate you need the measurements to be.
