Wow, a flood of useful info guys.
As per Noidea & Bradc, I drained the balance of the oil last night. It's clear and has very low viscosity. I only got ~1cc out of it.
I've looked online at some compressor oil from local auto spares. I wonder if it will be too thick and I should just put some light machine oil into it?
I'll try do do this slowly to avoid potential "hydraulic locking" that noidea picked up on.
I'll guarantee if you punch the model number into google and dig up the data sheet it'll take a *lot* more than 1cc of oil. More like 100cc.
If you are worried about oil viscosity, use air-tool oil instead. It's ISO32 and much lighter than pretty much most refrigeration oils. You'll spew a lot more out though as the lighter oil will get whipped up into a thicker mist which will get ingested and ejected. Again, the manufacturers data sheet will tell you what oil it's supposed to take if you are really concerned. All of the reputable compressor manufacturers have comprehensive data on their devices.
Don't worry about hydraulic locking. The suction tube empties into the shell, the actual intake for the compressor is right up the top of the shell. You could half fill the shell and not worry about a hydraulic lock. What you'd to do the rest of the mechanism with drag is another story altogether.
noidea is right. These compressors are designed for vapor return. Having said that, a small amount of liquid return is generally survivable as it will evaporate inside the shell. It will generally result in oil foaming and cause lubrication issues though, so it's a big no-no in a functioning system.
They are designed to cope with liquid, and if you read the compressor data sheet it'll give a maximum system charge. This is the volume of liquid refrigerant that it'll tolerate in the compressor shell at startup (designed for those one in a million instances when the compressor is the coldest part of the system and all the liquid migrates there). Usually in excess of a hundred g or so which for r134a works out somewhere around 80ml. That is less than the oil volume as the liquid refrigerant dissolves in the oil. When the compressor starts up the refrigerant starts to boil out vigourously and the oil pretty much fills the shell with foam. More liquid than specified can lead to damage through hydro-lock of the thick foam or bearing damage due to foam not lubricating properly. Always good to read the data sheet when building a refrigeration system
