Author Topic: Looking for a 12-48V Brushed motor driver with PWM input, Recommendations?  (Read 147 times)
Offline Alex_BakerTopic starter
I am working on a project the requires a motor driver (ESC) with RC PWM input and a rather wide input voltage range.
The input voltage can range from 12V to 36V or a little higher, current requirement is no more than 20A. I have no trouble finding motor brushed motor driver that can handle the power and voltage, the trouble is finding one with a RC PWM input. I am using a standard RC radio to control the motor.
I currently have a SyRen 25A, which works great but is only rated to a nominal 24V, 30V max.
Could anybody here recommend a motor driver that doesn't completely blow the budget? I am located in the USA.
Much appreciated!
Alex
Re: Looking for a 12-48V Brushed motor driver with PWM input, Recommendations?
« Reply #1 on: December 28, 2024, 08:58:19 pm »
I have found this: https://www.ebay.com/itm/166558180713
It's claimed specs would be perfect. but I am a bit wary of these ebay magic boxes.
