Author Topic: Looking for a connector, but do not know what it might be called  (Read 554 times)
Offline AndersJTopic starter
I need a connector with the same functionality as a 3,5 mm earphone jack
that opens a existing circuit and connects a new one.
Just like a legacy earphone that disconnects a speaker and connects the earphone instead.
Or the connector of a power supply, that disconnects the battery when plugged in.
But I want something more robust, like an XLR connector.
Are such connectors available, and what are they called?
Thanks for comments or suggestions.
"It should work"
R.N.Naidoo
Offline sokoloff
Re: Looking for a connector, but do not know what it might be called
« Reply #1 on: June 22, 2019, 06:44:30 pm »
You could try the 1/4" equivalent of the 1/8"/3.5mm version. Those are physically more robust.
In terms of having something XLR with a switch, the Neutrik NC3FBV2-SW seems like it would fit the bill. ( https://www.neutrik.com/en/product/nc3fbv2-sw )
The following users thanked this post: AndersJ
