Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
PCB Trace Width for 10A Servo Motor
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: PCB Trace Width for 10A Servo Motor (Read 2726 times)
K1JOS
Regular Contributor
Country:
on:
November 19, 2014, 01:36:13 pm »
I have a proprietary (no schematic) servo motor (12vdc, 10A startup) controller used outdoors that got zapped in a lightning surge. I have replicated the circuit that uses 4 MOSFETS (2 N and 2 P enhanced channel -- IRL540N and IRF 5210) in a H bridge controlled by as PIC18F MCU. I was surprised to see on the original board that the traces carrying the 10A +12vdc was only 2mm wide. I cannot tell how thick the copper plane is but it doesn't look any thicker than most of the PCB's for low voltage applications.
Is 2mm wide enough or should the design be as wide as possible - like the large ground plane on the PCB bottom?
thanks in advance for any advise
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: PCB Trace Width for 10A Servo Motor
Reply #1 on:
November 19, 2014, 04:04:33 pm »
I would go with 2oz and 100-200 mil (2.5-5mm) width (or build the route out of polygons of similar average width).
If that's 10A continuous, that is. If it's only pulsed for much shorter periods (0.1s?), you can get by with less.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
